Allen's Offroad
Free Shipping on all complete systems listed below!
Free Shipping: UPS ground or truck freight in the lower 48 US only.
Use your American Express or bank wire transfer and Save!
RKXJ45SAFS 4.5" Short Arm Flex System w/ Add a Leaf and Billet Aluminum Block Rear $849.00
RKXJ45XFSA 4.5" X Factor Short Arm System w/ Add a Leaf and Shackle Rear $1,099.00
RKXJ45TTSA 4.5" Triple Threat Short Arm System w/ Rear Deaver Leaf Springs $2,199.00 - Add $100 for spring handling fee
RKXJ45XF+LA 4.5" X Factor Plus Long Arm System w/ Add a Leaf and Shackle Rear $1,399.00
RKXJ45TTLA 4.5" Triple Threat Long Arm System w/ Rear Deaver Leaf Springs $2,499.00 - Add $100 for spring handling fee
RKXJCOMP45XF 4.5" X Factor Plus Long Arm System w/ Rear Coil Conversion $2,499.00
RKXJCOMP45TT 4.5" Triple Threat Long Arm System w/ Rear Coil Conversion $2,699.00
RKXJ65XF+LA 6.5" X Factor Plus Long Arm System w/ Add a Leaf, Shackle and Billet Aluminum Block Rear $1,499.00
RKXJ65TTLA 6.5" Triple Threat Long Arm System w/ Rear Deaver Leaf Springs $2,799.00 - Add $100 for spring handling fee
RKXJCOMP65XF 6.5" X Factor Plus Long Arm System w/ Rear Coil Conversion $2,499.00
RKXJCOMP65TT 6.5" Triple Threat Long Arm System w/ Rear Coil Conversion $2,699.00
RKYJCOMP7-AC-AC X Factor Plus Comp 7 w/ Front Coil Over Conversion [MADE TO ORDER] $3,999.00
RKYJCOMP7S-AC-AC X Factor Plus Comp 7 Stretch w/Front Coil Over Conversion [MADE TO ORDER] $4,049.00
RKYJXF+LA-UPG-AC-AC X Factor Plus Long Arm Upgrade [MADE TO ORDER] $2,549.00
RKYJTTCOMP8-AC-AC Triple Threat w/ Front Coil Over Conversion [MADE TO ORDER] $4,049.00
RKYJTTCOMP8S-AC-AC Triple Threat Stretch w/ Front Coil Over Conversion [MADE TO ORDER] $4,049.00
RKYJTTLA-UPG-AC-AC Triple Threat Long Arm Upgrade [MADE TO ORDER] $2,649.00
RKYJSTRETCH-UPG YJ Stretch Upgrade System [MADE TO ORDER] $949.00
RKTJ35SAFS-01 3.5" Short Arm Flex System $999.00
RKTJ35SAFS-02 3.5" Short Arm Flex System $999.00
RKTJ35XFSA 3.5" X Factor Short Arm System $1,449.00
RKTJ35XF+SA 3.5" X Factor Plus Short Arm System $1,649.00
RKTJ35XF+LA-01 3.5" X Factor Plus Long Arm System $2,399.00
RKTJ35XF+LA-02 3.5" X Factor Plus Long Arm System $2,399.00
RKTJ35TTLA-01 3.5" Triple Threat Long Arm System $2,649.00
RKTJ35TTLA-02 3.5" Triple Threat Long Arm System $2,649.00
RKTJCOMP35-01 X Factor Plus Comp 3.5 Coil Over System $3,799.00
RKTJCOMP35-02 X Factor Plus Comp 3.5 Coil Over System $3,799.00
RKTJ55XF+LA-01 5.5" X Factor Plus Long Arm System $2,449.00
RKTJ55XF+LA-02 5.5" X Factor Plus Long Arm System $2,449.00
RKTJ55TTLA-01 5.5" Triple Threat Long Arm System $2,649.00
RKTJ55TTLA-02 5.5" Triple Threat Long Arm System $2,649.00
RKTJ55XF+LAS-01 5.5" X Factor Plus Long Arm Stretch System $2,549.00
RKTJ55XF+LAS-02 5.5" X Factor Plus Long Arm Stretch System $2,549.00
TJTT55LAS-01 5.5" Triple Threat Long Arm Stretch System $2,699.00
TJTT55LAS-02 5.5" Triple Threat Long Arm Stretch System $2,699.00
RKTJCOMP55-01 X Factor Plus Comp 5.5" Coil Over System $3,799.00
RKTJCOMP55-02 X Factor Plus Comp 5.5" Coil Over System $3,799.00
RKTJCOMP55S-01 X Factor Plus Comp 5.5 Coil Over Stretch System $3,949.00
RKTJCOMP55S-02 X Factor Plus Comp 5.5 Coil Over Stretch System $3,949.00
RKTJCOMP7S-01 X Factor Plus Comp 7.0 Coil Over Stretch System $3,999.00
RKTJCOMP7S-02 X Factor Plus Comp 7.0 Coil Over Stretch System $3,999.00
RKWJ35XFSA 3.5" X Factor Short Arm System $1,299.00
RKWJ35LAFS 3.5" Long Arm Flex System $1,699.00
RKWJ55XF+LA 5.5" X Factor Plus Long Arm System $2,299.00
RKWJ55TTLA 5.5" Triple Threat Long Arm System $2,599.00
RKLJ35SAFS 3.5" Short Arm Flex System $999.00
RKLJ35XFSA 3.5" X Factor Short Arm System $1,449.00
RKLJ35XF+SA 3.5" X Factor Plus Short Arm System $1,649.00
RKLJ35XF+LA 3.5" X Factor Plus Long Arm System $2,399.00
RKLJ35TTLA 3.5" Triple Threat Long Arm System $2,649.00
RKLJCOMP35 X Factor Plus Comp 3.5 Coil Over System $3,799.00
RKLJ55XF+LA 5.5" X Factor Plus Long Arm System $2,449.00
RKLJ55TTLA 5.5" Triple Threat Long Arm System $2,699.00
RKLJXFCOMP55 X Factor Plus Comp 5.5 Long Arm System $3,799.00
RKJK25SM 2.5" Stock Mod Suspension System $499.00
RKJK25MT 2.5" Max. Travel Suspension System $1,149.00
RKJK25MT-PRO 2.5" Max. Travel PRO Suspension System $1,599.00
RKJK35EL 3.5" Entry Level System $499.00
RKJK35FS 3.5" Mid Arm Flex System $1,199.00
RKJK35XF 3.5" X Factor Mid Arm System $1,699.00
RKJK35XF-PRO 3.5" X Factor PRO Mid Arm System $2,499.00
RKJK35XF+ 3.5" X Factor Plus Mid Arm System $2,079.00
RKJK35XF+LA-2 3.5" X Factor Plus Long Arm System $2,499.00
RKJK35XF+LA-4 3.5" X Factor Plus Long Arm System $2,499.00
RKJK35TTLA-2 3.5" Triple Threat Long Arm System $2,699.00
RKJK35TTLA-4 3.5" Triple Threat Long Arm System $2,699.00
RKJK35TTLA-PRO-2 3.5" Triple Threat PRO Long Arm System $3,999.00
RKJK35TTLA-PRO-4 3.5" Triple Threat PRO Long Arm System $3,999.00
RKJKCOMP35-2 3.5" X Factor Plus Coil Over Long Arm System $3,799.00
RKJKCOMP35-4 3.5" X Factor Plus Coil Over Long Arm System $3,799.00
RKJK55XF 5.5" X Factor Mid Arm System $1,899.00
RKJK55XF+ 5.5" X Factor Plus Mid Arm System $2,279.00
RKJK55XF+LA-2 5.5" X Factor Plus Long Arm System $2,849.00
RKJK55XF+LA-4 5.5" X Factor Plus Long Arm System $2,849.00
RKJK55TTLA-2 5.5" Triple Threat Long Arm System $2,999.00
RKJK55TTLA-4 5.5" Triple Threat Long Arm System $2,999.00
RKJKCOMP55-2 5.5" X Factor Plus Coil Over Long Arm System $3,999.00
RKJKCOMP55-4 5.5" X Factor Plus Coil Over Long Arm System $3,999.00
RKJKCOMP55S 5.5" X Factor Plus Coil Over Long Arm Stretch System $3,999.00
PM me your name, billing and shipping address, phone number, email address (for PDF receipt) to order. I will call you for CC info.
Thank you very much. I am truly grateful for your business.
Namaste,
Allen
