J Johnnie New member Oct 21, 2006 #1 Hi, just put on new solex carb, points, condenser,rotor,cap,wires,coil,plugs and have a bad rough idle. Smells like unused gas when running idle doesn't die just rough seems to get better when higher RPM's. Any ideas? Thanks, John
willysworker New member Jan 6, 2007 #2 I assume you are smelling rich exhaust? check reading on vaccum gauge. If it's steady , adjust the carb mix to get highest reading.
