Rugged Ridge XHD Winches 8500 lb and 10500 lb, Starting at $299.99 Steel & Synthetic
Status
Not open for further replies.
Baseline 4x4
Rugged Ridge XHD Winches 8500 lb and 10500 lb, Steel & Synthetic
Durable. Tough. Affordable. The Heavy Duty 8500 LB Winch from Rugged Ridge is everything you could want in a winch. It is driven by a durable 5.5 HP Series Wound motor for long life and extra pulling power. A tough 3 Stage Planetary Gear box with a 172.8:1 gear ratio delivers power and reliability on each and every pull. The Heavy Duty 8500 LB Winch has more power and exclusive features than any other winch in its price range: Stainless Steel Hardware- All the exterior winch body screws and bolts are Stainless steel to prevent rust and provide a long life. All Rugged Ridge steel cable style Winches include off road light mount roller fairleads allowing for the easy mount of two off road lights! Special Solenoid mounting brackets allow for multiple solenoid mounting points and the ability to “tilt” the Solenoid for ease of use. This “tilt” feature ensures that each Rugged Ridge winch can be used with almost all off road bumpers and over riders! Limited 3 year warranty against manufacturing defects. Each winch has been independently tested to ensure they meet or exceed all specifications.
Heavy Duty 8,500 LB Winch Features & Specifications
• Durable 5.5 HP Series Wound motor for long life and extra pulling power
• Tough 3 Stage Planetary Gear box with a 172.8:1 gear ratio
• Includes 94’ of 5/16” diameter wre rope and latched hook
• Automatic load holding brake system (in the drum brake system)
• Exclusive light mount roller fairlead included- allows for easy no-drill mounting of up to 2 off road lights!
• Tough stainless hardware on the body of the winch to eliminate rust
• Each winch includes a durable 12’ all weather cable remote.
Fits:
10" x 4.5" Standard Winch Plates
15100.01 - Rugged Ridge Heavy Duty 8.5 XHD 8,500 LB Off Road Winch
15100.02 - Rugged Ridge Heavy Duty 8.5 XHD 8,500 LB Off Road Winch, Prewound with Synthetic Rope
15100.10 - Rugged Ridge Heavy Duty 10.5 XHD 10,500 LB Off Road Winch
15100.11 - Rugged Ridge Heavy Duty 10.5 XHD 10,500 LB Off Road Winch, Prewound with Synthetic Rope
Also check out our Jeep Wrangler Winch Plates.
11238.10 - Rugged Ridge Universal Winch Mounting Plate, 87-95 Jeep YJ Wrangler And 97-06 Jeep TJ Wrangler
11238.12 - RUGGED RIDGE RAISED WINCH PLATE, JEEP WRANGLER (YJ) 87-95, (TJ) 97-06
Whats the warranty mine burnt up after third pull.
Re: Rugged Ridge XHD Winches 8500 lb and 10500 lb, Starting at $299.99 Steel & Synthe
PM Sent. Let me know if you need any additional information.
Status
