i swaped my 87 4.2 liter for a 89 and found out they use different starters. the 87 has one wire that runs from the sylenoid to the starter the 89 requires two power sources one to turn the gear the other to engage it.I bought an extra starter cable and attached both to the sylenoid and to the starter, it only spun i then removed one of them and touched it to the battery terminal. the engine turned over and started but it will not stop engaging until removed from the terminal. how can i wire this thing in. any suggestions.
