Tank material on a 94YJ
jfrabat
Hey, guys, I have a 94YJ, and was wondering if this model has a metal or poly tank. If it helps at all, mine is the 2.5L engine, and I did do the 20 gal conversion... When I did this, it seemed like a Poly tank, but I dont know if it is just the conectors that are made of plymers or the whole tank.
Felipe
Mine lloked like a poly tank, but I just wanted to make sure that it was not just the tips... I only saw it (in the dark) when I was doing the 20 gal conversion, and I was not really paying attention to it at the time.
Anyone know a good product to clean the inside of a poly tank?
Felipe
Soap and water. Just get it all out.
I usually just swirl some fresh gas around and make sure all the crud gets out.
It was most defenetly a poly tank. I used the POR-15 Marine Clean to clean the tank, as it said it could be used on Vinyl, and boat bilges, so I figured it would not harm the tank. When I drained the first load, I could tell it was working... There was quite a bit of varnish and gum in the tank! And the tank was not damaged at all. Thanks for the help!
