bryanjeep, make sure you go ahead and stuff a good shiftkit in there too. TransGo makes the best one, but it's expensive. B&M and TCI are both okay, and either one works fine. A shift kit is seen as a bad thing by some people, but making the shifts happen quicker will extend the life of your transmission because it reduces slippage. Because higher heat is generated during the shift, reducing the amount of time it's spent shifting should make it run slightly cooler too.
