Sacredgroove
leaking at backisde of valve cover on stock 4.2 84 cj7.
i have replaced the valve cover with normal gasket,double cork gasket, & the right stuff. it had an aftermarket aluminum cover i changed out to another when gasket changes didnt do the job but it is still pouring out the backside of the cover down the rear of the engine to the tune of a quart a day if i drive it alot.
ive switched out gaskets, a jeep speciality shop switched out gasket and put in "the right stuff" and i recently went back and changed to a new cover and cork gasket thinking maybe the old cover was warped to no avail. any ideas as to what could be causing this?
thanks!
thanks!
