For months now I've been trying to find a way to take the doors off my Wrangler and have the dome lights stay off.
I tried buying little spring loaded contraptions that would attempt to keep the door pins depressed, but they would pop right off, threatening to put someone's eye out. I also tried pulling the door fuse, which works, but you'll need the fingers of a 6 year old boy to fit in there. Finally I found a solution - Quadratec's TJ Dome Light Switch.
This device is so simple that it's brilliant. You replace the door fuse with two leads that go to a switch (mounted under the dash in reach of the driver). There's an inline fuse to protect your circuit, and the construction of the harness is great.
You can find this switch by going to Quadratec's website and looking for "dome light switch".
The verdict - I love this thing. Probably the best $25 I've spent on my Wrangler so far.
