TWDJ
Next spring, I'm going to install a SLE and new driveshaft so the Xfer case lowering kit can be removed, however, the rear U-Joint has failed and needs to be replaced. There is no $$ in the budget at present for the SLE, etc so it is necessary to replace the existing U-Joints.
I've seen posts for U-Joints specifying 1310, 1330, etc but am not sure what to be looking for as the stock 93 YJs appear to use the 1310. Now for the real question.
I'm going to replace all 4 U-Joints because if one fails the others can't be far behind. Who does this board feel builds the best U-Joints? Should I get the sealed type or lubricating type.
Thanks for the assist!
