Cacarter126
So this process started with an 89' carbed yj that I recently purchased. I knew the carb needed a rebuild but I decided to buy a mc 2100 and just replace it instead. Here is where the issues started. I started looking around to see how complicated the install would be and discovered about a half inch of oil in my air cleaner. I assume it's coming from my PCV valve and if there is a fix out there the help would be much appreciated. Also, how intense is the swap between the Carter and the motorcraft? I have the transfer plate and gasket and electric choke already on the carb. Is this something I should hae someone do or is it something a novice could achieve. I purchased the mc 2100 from the eBay guy that sells the kits. That is the first set of issues.
The second set of problems deals with shackle lift that I recently installed fom full traction. Before the install I noticed transmision fluid where the drivshaft met the transfer case. Not very much at all. After installing the shackles the leak increased considerably. It throws transmisson fluid all over the undercarage. I don't know if this could be a seal or what, but it certainly wasn't helped by the increase in driveshaft angle. Which leads me to my next issue...dreaded driveshaft angle.
I was stupidly un informed that this would be such an issue. Since puting the shackles on, I have a vibration that I now know I should have known would need to be addressed. What are my options in correcting the angle? Transfer case drop or sye? I'm kind of clueless in this.
This leads me to my final issue. After installing the shackles and puting the weight back on the springs, the front springs are literally flat if not almost bent in the opposite direction. The shackles in the middle of the vehicle ( so the rear shackles on the front springs are hanging straight down if not slightly angled back. I actully lost ground clearence because the hanging suckle just described is lower then my pumpkin balls? Is this right?? The whole thing just looks unsafe. Is this correct? Are my springs to weak and can't hold their arch? And should the the center shackles e angles back? Could I solve this by leaving the very front and very back set of shackles and removing the center (rear shackles of front spring) ones. Simply bolting the rear of the front spring back to the frame, effectivly forcing an arch. Or are new springs needed?
I know this is all a lot and I'm sure I sound like an idiot but I'm really stuck and don't even think the think is driveable. Please any help is very much appeciated. Also I appologize for any spelling error, I types this on my phone.
