1985 cj body mounts stuck and broke
85cj
HAS ANYONE NOTICED RUBICON REAR BRAKES DO NOT WORK WELL
i have an 85 cj and the body mounts will not come out of the holes. they just keep spinning like there is a nut on the other end. is there maybe an easier way of getting them out without cutting the body apart?
RE: Bush
Which mounting locations?
Good luck. When I did my tub swap I didn't have much problem with that. Only 2 body mounts were intact!
RE: Gauges acting wierd when I hit the brakes or go over a b
You can try to drill a hole real close next to the mount and tap a screw in their to hold the peice of steel in the bodyand use lots lubricant. I cut the bolts ground them down, redrilled the hole and retapped the holes.
RE: 1998 2.5td
i just grinded the bolts off with a dye grinder when i ripped my body off
