Craig,
I thought I had everything covered. I guess not! I did not. I did the ignition error code trick and got a 12 code. (battery disconnect in last 50...) Which it has been. On the ride to work this morning the temp gauge still sits around 200 degrees. I was going to drain it this week anyway to fit it with some more perment plugs (I have a standard). When I do that I will be sure to check for foam. Hopefully I didn't overlook such a dumb thing!
