jackobotz
I was reading an add about renting a fender roller, or paying them to do it for you, never heard of anyone using one on a Jeep.
Fender Roller Rental
Don't Ruin Your Expensive Tires - Eliminate tire rub on lowered vehicles!
A must have for lowered vehicles and vehicles with larger wheels
Eliminate tire rub - Increases tire to fender clearance
Adjustable forming roll gradually rolls inner lip flat
Non-Marring forming roll preserves original finish
Adjustable arm length fits a wide range of automotive and light truck applications
Durable heavy steel powder coated construction
Universal Hub Mounted
Increase tire/fender clearance, flare fenders and/or repair wheel arch collision damage with this pro grade forming tool. Bolts directly to hub flange. Elongated holes in adapter plate fit all popular 4 and 5 bolt hubs, and are held in place with the included dished washers and vehicles lug nuts. Forming arm adjusts from 14" to 22 3/4 ball bearing forming roller is tough enough to form the fender without damaging the paint.
Tool Deposit* All rentals are subject to a deposit that EXCEEDS the list value of the tool ($250), plus rental fee ($50 for 4 days) + optional heat gun rental ($5 for 4 days)
In-Shop service also available for $40per corner (vehicle specific)
Damaged tools will only be charged at cost, with the balance of your deposit returned to the appropriate payment account or person.
The use of impact (air or electric) drivers will result in a loss of your deposit!
Any tool not returned in rental time will result in a loss of your deposit!
