oil pressure
ronnieb
hey guys , when rpm's run low, oil pressure goes down, could this be oil sending unit? no noise.:???:
and your oil pressure goes up when you rev and down when at idle because the pump is driven off the crank.
yes, i would worry then. you have enough oil in the engine, right? if so, then your pump either has a clogged, or partially clogged pick up screen or its on is way out.
driving will result in damage to your bearings and rotating assemblies in the engien
