1. Red face Brake Booster for 89 YJ Wrangler
    Do I need to replace the brake booster if, when I press the brake pedal, it goes almost to the floor, but if I pump it 3 or 4 times it builds up? Not good for a quick stop if someone pulls out in front of me.
    Dec 1999
    Virginia Beach VA
    8,026
    Re: Brake Booster for 89 YJ Wrangler
    That is normally a sign of air in the brake lines. Try bleeding your breaks and see if that helps.
    My 2005 Wrangler Build Thread
    I agree with Terry. Try bleeding the brakes.
    Bill Bell
    I did try to bleed the brakes, but it didn't help. Would the booster be the next thing to replace? Is there a way to test the booster? Also, has anyone used the "Speed Bleeders" for bleeding the brakes? It looks too good to be true.
    usually, a booster being bad will make a hard pedal or your idle will raise when you push the brake pedal. a spongy pedal is normally air in the brake lines, especially with your description
    google testing a brake booster and it will pop up exactly how to test yours.
    are you asking about the speed bleeder little things that go on your calipers? i have on my bmw. they worked fine for me
    Jan 2012
    Kelowna B.C. Canada
    15
    I agree with the air in the lines but, also if rear brakes are way out of adjustment the pedal will pump up after the wheel cylinder pistons push out far enough for the shoes to contact the drums.
  7. #7
    Dec 2006
    San José, Costa Rica
    1,693
    You could also have a small leak somewhere in the system. My rear drums had a small leak, and it really affected my braking performance, as the pressure would "escape" through the leak. If you DO decide to change the booster, I would recommend trying to make the 95.5 model fit (you'll need the master as well), as it is a double diaphragm design, but, to be honest, I doubt this is your issue. And if tried bleeding, try raising the front of the Jeep and turning the wheel from one side to the other with the Jeep off a couple of times; sometimes bubbles get trapped and are hard to get out.
    '94 YJ 2.5L, Sperwinch EPi 9.0, RE 4" Std Lift, Adv. Ad. SYE, Woody Shafts, Alloy Axles, ARB Lockers, 4.88 gears, 62mm TB & Spacer, 165A Alternator, Griffin 3" Aluminum Rad, Taurus e-fan w/ DC Controller, Borla Cat-Back, Flowmaster hiflow cat, PD Ignition, 19# injectors, Adj. FPR (42PSI), MOPAR cam, Safari Snorkel, 33" BFG KM2, 15" AR wheels, Xenon H4 lights, KC Daylighters & Slimlites, Sony sound, Pavement Ends Targa Top, Hanson Front Bumper, JCR Offroad rear, AtoZ Rockers, Rhino lined Tub.
  8. #8
    Dec 1999
    Virginia Beach VA
    8,026
    My suggestion would be to park on some clean concrete and pump your brakes for a while, then crawl under your Jeep and look at each wheel's brakes for fluid. You may need to come back the next morning and look again.
    Do you need to add fluid in your master cylinder periodically?
  9. #9
    Quote Originally Posted by TerryMason View Post
    No. That is what is confusing. There is no drop in fluid level. No wet spots around any of the bleeder valves. No leaks from fittings. What I noticed today is that if I pump the brakes I can hear an air sound from under the brake pedal area. Do you think some part of the booster is leaking from the back? Thanks.
  10. #10
    I hate to show my limited knowledge, but you guys seem to know your stuff and I guess I'll not learn unless I ask. Do I have to jack up the Jeep to bleed the brakes? I can get under because of the height, easily. Thanks.
  11. #11
    the air is normal because the booster runs off vacuum. it should make that noise.
    you should be able to lay right in front of or right behind each wheel and reach the bleeder screw with no jack.
  12. #12
    Thanks a lot for all the advice. Will try these things tomorrow and will post which one it was.
  13. #13
    i decided to bleed the brakes again and that seems to work this time, so thanks again for all the replies.
  14. #14
    Sometimes you have to drive it with a soft pedal for a while to allow the air to move outwards. I've had the same issue previously and waiting a week and then rebleeding fixed it
  1. Brake booster and master cylinder
    By 90Xjay in forum Items for Sale, Trade, or Give Away
    Last Post: 06-22-2007, 06:57 PM
  2. CJ Brake Booster
    By jay79cj7 in forum Wrangler and CJ
    Last Post: 06-12-2007, 08:44 AM
  3. Brake Booster
    By Sly8795 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 12-18-2004, 01:16 AM
  4. CJ7 power brake booster rebuild kit?
    By berettajeep in forum Wrangler and CJ
    Last Post: 01-19-2004, 11:45 AM
  5. Brake booster bracket
    By TerryMason in forum Items for Sale, Trade, or Give Away
