Jeepin_guy95
I've decided its time to step up and finally get some real meat stuffed under the fenders of my '95. My jeep is completely stock except for a 1" body lift and sway bar disconnects. I want to go with a SOA and ditch the stock axles. I just dont have a clue what sort of a donor truck I should be looking for. I'm aiming to fit the biggest tires I can and use TJ flares. I try and do mostly rock crawling, but the Jeep sees just about every type of terrain, so I need ground clearance and flex. [addsig]
