1. 97 wrangler fuel pump relay no power
    I have a 97 wrangler 6 cylinder. Parked it one day and came out the next and it won't start. It has a full tank of fuel but the fuel gage reads empty (Its always worked. Ive checked fuel pump, relays, fuses. Im stumped. It cranks easily. The fuel pump relay does not engage when the ignition is on. Ive verified its a good relay. Im thinking its either the ignition switch itself or the darn computer. Anyone have any insight ?
    Feb 2009
    Dayton Ohio Area
    5,322
    Start with checking fuses, wires and voltages. Start at the ign and fuel pump.
    Re: 97 wrangler fuel pump relay no power
    Check the fuse for the ASD circuit under the hood in the PDC. Also swap out the ASD relay for another relay and see if that helps.
  4. That happened to my 2002 TJ. Had a broken wire somewhere in the harness so I just tapped into the Relay in fuse panel and ran a new wire alongside the harness.
  1. 1992 wrangler fuel pump wiring
    By tailights24 in forum Wrangler and CJ
    Last Post: 08-04-2010, 11:54 PM
  2. Replaced Fuel pump, now no spark?
    By tannerp89 in forum Wrangler and CJ
    Last Post: 07-21-2010, 11:42 AM
  3. 96 cherokee good fuel pump,relay no start
    By charity in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 05-13-2010, 10:57 PM
  4. 93 Wrangler fuel pump.
    By Gregorypaul in forum Wrangler and CJ
    Last Post: 04-09-2009, 08:23 PM
  5. jeep died - fuel pump relay clicking loudly
    By joeycj5 in forum Wrangler and CJ
Tags for this Thread
