1. 1978 cj7 steering wander
    I have a untouch barn find 1978 cj7 golden eagle not lifted
    I have replaced the leaf springs new bushing new gas kyb shocks
    Tie rod and using street tires.
    Please how do I stop the steering wander especially on curvy roads
  2. Re: 1978 cj7 steering wander
    I have a 79 cj7 and I just replaced shocks and also the steering stabilizer. The stabilizer on mine was trashed and it made a big difference, i had lots of play until I put the new one on. Just a suggestion.
    Thank you
    My cj did not come as original with a stabilizer
    Thanx
    Feb 2009
    Dayton Ohio Area
    5,402
    @ Tbone711 and Cmsjaffe. Steering stabilizers are to take the snap out of steering when you hit a big bump or pothole. You could run without one. It will not fix wander or bump steer or DW.
    Im cheep and wouldn’t spend my money on this to fix your issue.
    As mentioned in another thread. Check alignment tir and caster.
    Do a dry steer test and consider adding a steering box support.
  5. Re: 1978 cj7 steering wander
    Check your hub bearings.They could be worn, or the nuts could've backed off.
    Also, if you have manual steering, you might need to adjust any slop out of that, as well.
    You said that you replaced the tie rod. What about the steering link? Are the ends in good condition, or, are they worn?
  1. steering wander
    By n8dgr8 in forum Wrangler and CJ
    Last Post: 12-08-2019, 11:09 PM
  2. 1978 cj5 steering column
    By teamyz450 in forum Wrangler and CJ
    Last Post: 05-27-2014, 09:20 AM
  3. Front end wander
    By 01jeepgc in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 11-16-2012, 08:00 PM
  4. wander
    By lippy in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 02-10-2007, 10:41 AM
  5. steering wander?
    By Crewdude007 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 05-25-2006, 10:12 AM
