    2015 JKU Key fob won't lock/unlock doors
    So I have a weird issue. The key that has been in the ignition will not lock doors or unlock. The spare key will work fine. We changed batteries in both fobs and disconnected the battery to reset. The only other thing is it usually says that the key is in ignition even when its been removed? Just checking to see if there are any quick fixes before I bring it to the dealership....to get robbed.
    Feb 2009
    Dayton Ohio Area
    5,194
    Re: 2015 JKU Key fob won't lock/unlock doors
    So just to clarify. The key you use daily will not mechanically unlock the door or remotely will not unlock the door? And it mechanically will start the jeep when in the ignition. Or the remote start the jeep?
    The indicator that the key is in the ignition is likely the issue.
    I'll post back a security key reset you could try.
    Regards,
    JPNinPA
    Sent using TapTalk
  1. nav and dvd unlock?
    By ogradystereo in forum Jeep Electronics and Audio
    Last Post: 07-02-2011, 03:46 PM
  2. Installing new lock cylinders in Jeep hardtop doors
    By TerryMason in forum Accessories
    Last Post: 01-25-2008, 11:11 PM
  3. To auto lock or manual lock~ That is the question
    By jps4jeep in forum Wrangler and CJ
    Last Post: 07-09-2004, 10:18 AM
  4. installing lock right/quick lock locker in model 20
    By n8dgr8 in forum Wrangler and CJ
    Last Post: 03-09-2004, 09:21 AM
  5. Half doors won't lock
    By MORGSTER in forum Wrangler and CJ
Tags for this Thread
