06-29-2020, 01:23 PM #1
climate control fan only works on high
Hey All,
I searched for this subject but could not find it in this forum. Sorry if it's been covered before.
The ac/heater fan in my 2005 Wrangler only works on the highest setting. I'm guessing it is a relay or a fuse. How do I go about troubleshooting it?...I'm a newbie.
Please and thank you.
06-29-2020, 09:42 PM #2
Its a resistor. Easy to access and change behind the glovebox
2005 JEEP WRANGLER 4.0L L6 Blower Motor Control Module / Resistor | RockAuto
Never look down on anyone unless you are helping them up - Jesse JacksonLast edited by JPNinPA; 06-29-2020 at 10:15 PM.
06-30-2020, 06:13 AM #3
Re: climate control fan only works on high
Hopefully that will fix it for you.
I used to have an XJ and the fan got where it would only work on high and then it got where it was slow to turn on. I lived with it for about a year and then replaced the fan motor to fix it.
07-12-2020, 11:56 PM Thread Starter #4
07-13-2020, 12:02 AM Thread Starter #5
07-13-2020, 09:08 AM #6
No problem. Im sure you could do this.
Working in and under the dash is a pain sometimes but this one is straight forward.
Personally i think the resistors fail for 2 reasons. One is leaving the fan on lower settings when the engine is started. The onrush of current from the fan starting is too high fir the resistor for repeated occurrences. Second is electro-migration. If you look the resistor is made of different widths and lengths of serpentine copper traces. This by physics gives different resistances resulting in different fan Speeds. Its the serpentine that is the time-bomb. Ill bet most if not all traces are blown at a corner of the trace and not along a straight run.
Anyway:
Inspect the connector for signs of overheating or melting. Jeeps yj, tj, wj,...from this era are noted for having an issue. If you see it, there are other things happening besides the resistor.
Never look down on anyone unless you are helping them up - Jesse Jackson"Never look down on anybody unless you're helping him up" - Jesse Jackson
Climate Control not working
By Twdg94 in forum Cherokee, Commander, Wagoneer and LibertyReplies: 1Last Post: 02-18-2020, 03:02 PM -
Climate control panel doesn't work
By Adam Velazquez Jr. in forum Cherokee, Commander, Wagoneer and LibertyReplies: 3Last Post: 01-22-2016, 06:23 AM -
climate control knob?
By RudeDog in forum Wrangler and CJReplies: 5Last Post: 09-04-2013, 03:49 PM -
Grand Cherokee Dual Climate Control Trouble
By PlasticNerd in forum Cherokee, Commander, Wagoneer and LibertyReplies: 3Last Post: 02-01-2011, 11:33 PM -
Rotary climate control in 98 TJ
By civicsiebp in forum Wrangler and CJReplies: 1Last Post: 05-17-2009, 03:18 AM
