Thread: Help help help
  1. Help help help
    Hey guys, I have a 2008 Wrangler and the hazards will not turn off. I have pulled every fuse and replaced the TIPM and no luck. Maybe it is an alarm but I do not have a remote. I live in Naples, Italy go just running to a Jeep dealer is an issue please help!
    Thanks
    Chris
    Feb 2009
    Dayton Ohio Area
    5,941
    Help help help
    Push the flasher button in and out many times. Possibly something was spilt or dirt got in.
    Other thoughts:
    Check battery
    Check/replace key fob battery
    Check/clean key fob panic button.
    Does your horn work? If not it may be an alarm system.
    Any lights on the dash blinking? Besides the flashers? Alarm or CEL? Does it start and stay running?
    Re: Help help help
    Thanks
    I tried pushing the button several times
    Yes the horn works
    Yes it runs
    I do not have a key fob
    Any other ideas?
    Thanks mate
  4. Re: Help help help
    Have you tried disconnecting the battery and leaving it disconnected for a period?
  5. Re: Help help help
    I have also read the TIPM has to be programmed.
    Feb 2009
    Dayton Ohio Area
    5,941
    Help help help
    Get your battery load tested. Low battery voltage does weird things.
    A simple but not full test is to measure battery voltage before start. 12.6V
    During start when cranking it should not drop to or below 10V more like 11V
    Once running it should read 14.4V
    Disconnecting the battery then try to start. This drains app stored power and resets the PCM. Reconnect the battery and see if it continues. If so you need a TIPM reset.
    This is done by removing battery then disconnect and clean the terminals of the wiring loom on the underside of the TIPM. Clean any corrosion. Reconnect it all.
  7. #7
    Re: Help help help
    Thanks everyone...I am going to try the load test (just because I already took the TIPM out, cleaned it and it has been off battery for a while)
    Is there any way to do like a "hard reboot" of the electrical system?
  8. #8
    Feb 2009
    Dayton Ohio Area
    5,941
    Help help help
    Jeep Wrangler JK: How to Reset Your ECU
    Step 1 – Remove the positive (red) battery cable. Use your wrench or ratchet to remove the positive battery cable. ...
    Step 2 – Ground the red cable to the negative terminal. ...
    Step 3 – Reconnect the positive battery cable. ...
    Step 4 – Turn on your Jeep. ...
    Step 5 – Cycle the headlights. ...
    Step 6 – Turn the key off and remove.
    Have you swapped any relays?
    Also consider disconnecting the switch to determine if the switch is broken.
    I understand the doors have something to do with the security system and blinking flashers. Might try unplugging the doors to see if it stops,
    Also consider resetting cables to the PCM.
    After that my top guess would be something sharing a ground or ground point with the flasher is resistive or bad. This will result in the current path changing and forcing power through the hazard circuit.
  9. #9
    Re: Help help help
    Thanks man I am going to try all of the above...I will let you know. I appreciate it...come to Naples and I will get you a pizza (best in the world)
  10. #10
    Feb 2009
    Dayton Ohio Area
    5,941
    Re: Help help help
    That sounds nice! Thank you.
    Good luck!
  11. #11
    Re: Help help help
    That didn't work!!! This thing is killing me!
  12. #12
    Feb 2009
    Dayton Ohio Area
    5,941
    Help help help
    So the hazards are on and flashing constantly...? Just verifying the flashing part.
    Have you contacted/called Jeep?
  13. #13
    Feb 2009
    Dayton Ohio Area
    5,941
    Re: Help help help
    Next i would see if there is a pCM check. The flasher signal comes from the switch to the PCM then to the flasher. Im uncertain if the flasher relay exists snd is under the column or not.
  14. #14
    Re: Help help help
    Yes they are flashing...I did not even think to call Jeep..I will....also I will look for the relay by the PCM...man you are big help, thanks
  15. #15
    Feb 2009
    Dayton Ohio Area
    5,941
    Re: Help help help
    Quote Originally Posted by Jeep in Naples View Post
    I may have confused something.
    I don’t think there is a flasher relay on JK models i believe the signal comes from the PCM. Call jeep to determine cause. Also if there is a PCM test to determine if the PCM is faulty. I hope not but if there is no alarm and no relay and the switch is good...thats the only thing left. Well grounds and low voltage ad stated earlier.
  16. #16
    Re: Help help help
    I honestly think it is a ground somewhere!!
  17. #17
    Re: Help help help
    Well it just got fixed 2 days ago. 3 exposed wires were touching a screw on the frame. I had the fenders re-done a while ago and when they put them back on somehow they did it to the wires....man what a gremlin!
  18. #18
    Feb 2009
    Dayton Ohio Area
    5,941
    Re: Help help help
    Glad you got it fixed. Those are the worst along with replacing bad parts with “new” bad parts.
  19. #19
    Re: Help help help
    Wiring issues like that can be a bear to find. Yrs ago my truck had a short in the wiring harness that took me a month to find, every time I put the tester on it the probe completed the circuit. Glad you got yours figured out!
Tags for this Thread
