87 Jeep Wrangler
carlr
I had the clutch replaced on our 87 Wrangler and now the clutch engages too close to the floor. The clutch is hydraulic and therefore I cannot figure out a way to adjust it. Any ideas? Also, I am new to this forum so I hope I am sending this question correctly!
Did you bleed the clutch?
On the slave cylinder rod was there a plastic/teflon end that was changed. If this is missing you have to push the pedal further.
