    Help finding a part
    So I tried to go 4 wheeling today and I couldnt switch into 4wd and my shifter was loose. I kee my center console unscrewed for this very thing but my transfer case bushing was still intact and good so I know it has to be the one connected the cable to the actual transfer case but cannot find the name of the part If you know please tell me. Its for a 2010 Jeep Wrangler JK
    Re: Help finding a part
    Shift linkage?
    03 rhd tj
    Feb 2009
    Dayton Ohio Area
    6,540
    Help finding a part
    Shift linkage
    BtW. This often goes bad or the cable pops out
    Its a linkage bushing
    Shift linkage
    Thats the one that goes on the underside of the car? So both ends use same linkage?
    I also have a 2010 JK and the bushing is the same on both ends of the cable. I've had to replace the transfer case side once and the shifter side twice.
    The book says you need to remove the skid plate but if you can work blind and get your hand in there you can replace it without removing the plate. Not easy but IMO better than having to do extra work.
    Quote Originally Posted by mark sr View Post
    Thanks! Ill probably do it that way then
  7. #7
    Shift linkage
    Do you know of any good after market transfer case cable replacement kits that eliminate the use of bushings
  8. #8
    i think morris 4x4 and any of the other off road places will have one, looking at google really quickly. it seems advanced adapters makes one, though it is expensive.
    03 rhd tj
  1. Need help finding parts
    By Sharkbait in forum Wrangler and CJ
    Last Post: 01-05-2020, 12:41 AM
  2. help with finding year of motor
    By oldman in forum General Chat
    Last Post: 02-25-2009, 07:17 PM
  3. trouble finding paint
    By factory47 in forum Wrangler and CJ
    Last Post: 01-31-2009, 05:14 PM
  4. Need help finding a transfer case
    By Sayre in forum Wrangler and CJ
    Last Post: 05-15-2008, 08:10 PM
  5. finding what gear
    By happy024 in forum Wrangler and CJ
    Last Post: 05-24-2005, 08:39 AM
Tags for this Thread
