Thread: Diff lockers?
09-11-2022, 06:16 PM #1
Diff lockers?
Does anybody know if the 2010 Jeep Wrangler sport jk had diff lockers?
09-11-2022, 10:46 PM #2
Re: Diff lockers?
Depends. Rubi or not?
2011 Jeep Wrangler JK Specs | Quadratec
Never look down on anyone unless you are helping them up - Jesse Jackson"Never look down on anybody unless you're helping him up" - Jesse Jackson
09-12-2022, 01:12 AM Thread Starter #3
Re: Diff lockers?
No just a base sport model
09-12-2022, 05:35 AM #4
Re: Diff lockers?
My 2010 JK Sahara has traction control which while not the same is close to being as good IMO.
09-12-2022, 08:56 AM #5
Re: Diff lockers?
not from the factory, no lockers but you should be able to get the codes off you diff tags and see if its limited slip or something like that
03 rhd tj
09-19-2022, 08:34 PM #6
Re: Diff lockers?
where or what, how, do I get the info with the tag numbers? Dealership maybe ?
Needs to go yonder.
09-20-2022, 08:10 AM #7
Re: Diff lockers?
no. the tag will have some codes on it with one being your gear ratio. if there is an L (or LS) on the tag, it means its got limited slip.
Differential Identification | West Coast Differentials
How do I determine my axle gear ratio? | Jeep Wrangler TJ Forum
no L or LS on this one /\03 rhd tj
09-21-2022, 05:49 AM #8
Re: Diff lockers?
ok thanks
Needs to go yonder.
11-26-2022, 08:28 PM #9
Re: Diff lockers?
Don't know what your plans are but if you are planning on getting a locker but don't rock crawl I would recommend truetracs i have them in the front and rear and there is no hesitation when one wheel slips just a little and with BLD it locks up the wheel in the air that has no traction and sends it to the wheel that does. It is the closest thing to a locker without all the trouble of one. I've had lockers and recommend the truetracs. Just my thoughts.
Yj front diff
By JaShar30 in forum Wrangler and CJReplies: 13Last Post: 09-23-2012, 04:09 PM -
Yukon Gears, Lockers,Axles,Install Kits,Spartan Lockers On Sale Now! + Free Shipping!
By 4wheelcustoms in forum 4x4 VendorsReplies: 0Last Post: 06-15-2012, 10:14 AM -
Diff Skids
By SeriousOffroad in forum 4x4 VendorsReplies: 1Last Post: 05-10-2012, 11:41 PM -
Diff oil question(s)
By Jason4x4 in forum Wrangler and CJReplies: 7Last Post: 09-14-2007, 01:02 PM -
welding diff
By blown XJ in forum Cherokee, Commander, Wagoneer and LibertyReplies: 14Last Post: 05-09-2007, 08:37 PM
