Jagered
Member
Looking for info on what wires yo yap into for this light bar setup I got through work.
Sent from my SM-S906U using Jeepz.com mobile app
I like these fuse block taps:
Fuse block taps on Amazon
From there you can plug into the headlights in your fuse block, or whatever circuit you want.
:shades:
... so now you understand my dilemma. I'm sure I could poke around and test each wire but was hoping someone had a wiring diagram showing color codes.
cheers!
Wiring diagram of what?
This is a sidestep light strip that acts as a courtesy/turn/running light... so needs to be tapped into the lighting for all of that stuff.![]()
This
Is this from the packaging of what you have?
