TwistedCU
The rubber connector on my front axle (to engage axle in 4wd) was disconnected. It may have been this way for as much as 3 weeks. It's been pretty wet around here and just wondering if there is anything I should worry about or need to do. I know I haven't used 4wd since it has been this way, because the shortly after the last time I used 4wd, I was under there with a hose cleaning stuff off and it was connected.
I'm going to put a small zip tie on both sides to prevent this from happening again!
