\'88 4.2L YJ serpentine belt help
kimjimi2
Any tips on getting a serpentine belt on an ’88 258ci / 4.2L Wrangler Larado (w/ PS and A/C) – having a ton of problems and can’t figure it out. This 4.2L lacks a spring loaded belt tensioner and the only bolt adjustable accessory is the alternator. Help!
[addsig]
1048836
there is a idler pulley below and to the side of the ac compressor identifing feature is a square hole that you can put a rachet into for tensioning after the bolts on the braket are loosened.hope I could help
[addsig]
