the rear springs are nearly identical, both 2.5" wide and both have the same approximate length. like mentioned, the fronts will be the issue. the springs are only 2" wide as opposed to the stock YJ 2.5 front. it could be done with 1/4 specers on either side of the spring on the frame mount and you could get the CJ to YJ conversion hangers and run them upside down. but there is absolutely nothing gained going with a weaker and less stable 2" cj spring
