jfrabat
OK, guys, I need your help; I just opened up my SYE kit (which, by the way, I ordered a PORC kit, and I received an Advanced Adapters kit, which is great!), and the installation instructions seem to make this install one complicated procedure...
Now, I have never assambled or disassambled a trasfer case, and half the parts they mention, I have no clue as to what they are... So, my questions are:
1) THE MOST IMPORTANT ONE: SHOULD I TRY TO DO THIS MYSELF???
If so...
2. Is this something I can do in a weekend? Keep in mind I have never done anything like this...
3. Will I be able to take out the yoke nut if I do not have an impact wrench?
4. How do I take out the Drive Sprocket Needle Bearings?
5. What lubricant should I use? They mention in some parts to pre-lubricate, and then to "fill with recommended ATF". Which pre-lube and ATF should I use?
6. What should I clean components with?
7. It mentiones that I do not need to disassamble the complete transfer case "unless you find foreign material inside ussually caused by a worn or stretched drive chain. You will need to be the judge." However, since this is the first transfer case I will see from the inside, I doubt I will be a very good judge here; what should I look for?
8. What are (pictures will help here!):
Your help is very much appreciated!!!!
Felipe
If so...
- The Speed-O-Drive? Is this where the speedo gear goes into?
- A yoke puller?
- The selector lever
- Output Shaft Boot
- Harmonic damper
- The oil pump pickup tube
- Drive Sprocket Needle Bearings
Felipe
