Zj with kor super duper track bar
dusterdude
About 6 months ago I put kevins heavy duty adjustable track bar in my zj.it worked great up until recently and now I'm getting death wobble again.I'm wondering if maybe I didn't grease the super durometer bushings well enough and maybe they wore out.my question is,if I have to replace them,does anyone know if there a suitable grease available in a grease gun tube for them?thanks
Sent from my LM-X420 using Tapatalk
First verify if and what went bad. Did bolts loosen or is a joint worn out?
I ask if you did anything to wear the bar? Water crossings. Mud, hit or bend it rock crawling,Flex like a lowrider bounces at competition?
Six months isn’t long enough to wear something out unless you are hard on it.
I use purple marine grease unless another is specified
