Lift Help
liljeepgirl
Hi, I have a 1990 Jeep Cherokee Laredo and I've been wanting to lift it for a long time now but I would like some advice first on what i should do to it. I would like at least a 3" lift but i want a lift big enough to fit 32 or 33" tires underneath. What size lift should i get and what brand lift kit would you recommend? Thanks for your help.
Chelsea[addsig]
1074246
With a 3 1/2 inch lift I'm running 31's. If you want to run 32's or 33's you have to either get a bigger lift or trim you're wheel wells. If you lift more than the 3 1/2 inches you will probably need a slip yoke eliminator besides the lift. As far as brand goes I have a Rubicon express lift and I like it a lot. If you want to give yoyr self a crash coarse in these things go toJeeps unlimited go to the Cherokee section and there is something there that they say every one should read before posting it tells you a real lot of information about things like this.[addsig]
