    eat_sleep_jeep's Avatar
    eat_sleep_jeep is offline Senior Member
    Jun 2003
    New Jersey
    126
    I changed my oil today to find some metal scrapings in there. Very tiny metal scrapings but a good amount of them. What could this be from??
    LGR's Avatar
    LGR
    LGR is offline Senior Member
    Mar 2003
    Leonia, NJ
    1,319
    mean green dual battery tray
    i'm sure a small amount is normal for wear and tear. So long as its not chunks right?
    LBR's Avatar
    LBR
    LBR is offline Senior Member
    Dec 2003
    Florence,Oregon
    412
    No scrapings are allowed in a healthy engine! A slight metallic look is OK after a 3000-5000 mile oil change and is considered normal, but no "scrapings" - could be any number of internal areas - I don't know much about your particular engine, but I'm sure the 2.5L gurus will point you to the main problematic causes LBR
    Plant the wheelie bars and let the games begin
    88Wrangles's Avatar
    88Wrangles is offline Senior Member
    Nov 2003
    Eugene, Oregon
    2,785
    Change your oil a little sooner than normal, and check to see if there is more metal in there. If there is, you might want to check things out in your engine, or find a mechanic to take a little look at it.
    LBR's Avatar
    LBR
    Dec 2003
    Florence,Oregon
    412
    It's also possible to send out a sample of your spent oil to a lab in your area to analyse it for type of metal shards - may give ya an idea of what part of the engine is giving way LBR
    Snitty's Avatar
    Snitty is offline Senior Member
    Nov 2002
    Olean, NY
    5,646
    likely a bearing going bad.... have you gotten any coolany in your block that you know of? that can often eat away at bearings... or it could be cam/lifter material
    93 YJ 4.0
  7. #7
    Jun 2003
    New Jersey
    126
    I'm not sure, I've never checked. Maybe I'll bring it to a garage and let them check it out. Thanks guys.
