    cbanks's Avatar
    cbanks is offline Junior Member
    May 2009
    16
    Jeep was stuck now running funny
    About 2 weeks ago i was driving in the snow and hit the break and slid of a hill. over the median and over a small wall, my jeep was stuck. It then snowed to about 2 feet and the next day i had to get my jeep out of this persons yard.
    After a few hours and rocking it back and forth for about a half tank of gas , i finally got out. My check engine light was on for the next 2 days but went off. I dented a rim and everything else seemed ok. now when i shift it feels like it is having a hard time getting into second gear.any ideas? i didnt know if rocking it like that was bad for it but i wanted to get out of this persons yard.
    I have a stock 05 wrangler. I am worried about it and dont know many mechanics around here. I have a friend who knows cars but not much about jeeps, what should I be looking for if something is wrong with it?
    Thank you in advance
    DREDnot's Avatar
    DREDnot is offline Member
    Feb 2010
    AZ
    38
    Re: Jeep was stuck now running funny
    Wow...Thats gonna be hard to diagnose over the innerweb.
    You have a few seemingly unrelated symptoms.
    Nothing I can think of that would cause the check engine light to come on would make it hard to shift into second gear.
    The only scenario I can dream up would be that either going over that wall with enough hate to dent a rim, or the forward to reverse over and over may have tweaked or broken your trans/motor mounts causeing the shifting issue.
    A worse case...you may have boogered up your syncros or something.
    The same prolonged revving/shifting/ revving/shifting may have caused the computer to see some sensors go out of range but now that you are back to normal driving, it has gone away causing the CEL to go out
    Hope this helps send you in the right direction
    Team Twisted Off Road's Avatar
    Team Twisted Off Road is offline Senior Member
    Jan 2010
    cedar springs
    161
    You may have somthing broke or bent? id call and ask a body shop that can fix frames and just ask them thay may have a idea on what it could be? as for the check engine light that is a hard one...
    shotgun's Avatar
    shotgun is offline Junior Member
    Aug 2008
    South NJ
    22
    try to look at transmission mount if your still haveing issues i dont think it would be your motor mount sounds like transmission mount definately. also look to see if you dented or bent your exhaust anywhere under the jeep that would aslo kick your light on because the o2 sensor is conected to your cataletic converter if you were not getting the proper flow of exhaust it will kick it on ... just my 2cents thats all
    J ust
    E mpty
    E very
    P ocket
    Crazy4diesels's Avatar
    Crazy4diesels is offline Senior Member
    Oct 2008
    Boston
    393
    Is this an automatic? If so you may have overheated the transmission - John
    DREDnot's Avatar
    Feb 2010
    AZ
    38
    From the way he described it in his post, it doesn't sound like he's got an auto.
  7. #7
    cbanks's Avatar
    May 2009
    16
    No it's a 6speed. It almost feels like it Wont go into gear at first when I try to put it in second, and sometimes it takes a second then clicks. Like it wasn't in gear yet.
    If the engine check light has turned off, does it seem like something I should worry about?
    Thank you everyone for your help. I wish I knew more about this
    thing!
  8. #8
    May 2009
    43
    Quote Originally Posted by cbanks View Post
    thing!
    if the chk eng went off, then the fault has not happened in x amount of cycles. So it appears all is good. You can still see what it was. Autozone will do a code scan for free last time i knew.
    Now about your odd shifting... Does it only happen in 2nd gear? If so, try this: before you shift into second, move the lever all the way to the right side (asif you were going to put reverse but dont pull it back for reverse) and then try to put it into 2nd. It should go in smoothly. if else, something is probably bent.
    In my new/used 2006 TJ it grinds if i put it into second too fast after first. i have to do the above for it to take second nice and quietly. I have not pinpointed the reason yet.
    ~0okami.Digital
  9. #9
    54cj3b's Avatar
    54cj3b is offline Senior Member
    Aug 2009
    Evergreen,Colorado
    1,520
    not going in gear could be thrown out sink row in trans ,busted mount , cluch going out ect as for check eng you prob over heated your catalitic most likly
    ALL I OWN ARE JEEPS!
    54CJ3B ,76DJ5RHD , 81DJ5RHD, 88XJ , (It's)93XJRHD(Alive), 06KJ ,
  1. Funny Jeep Quotes
    By Jeepfrk97 in forum General Chat
    Last Post: 05-10-2004, 07:48 AM
  2. H-Wing. not jeep but funny
    By LGR in forum General Chat
    Last Post: 02-09-2004, 12:12 PM
  3. Funny wannabe jeep site
    By Jeepster05 in forum General Chat
  4. Funny: you think Terry's got stuck in your head?!...
    By PASmokeater in forum General Chat
  5. Funny jeep video
    By jhiggins in forum General Chat
Tags for this Thread
