Lifted 2008 JK Unlimited sway problem
Pugsly
I am involved in the build of the above vehicle. The steering is really squirrely when you are over 30 MPH. it has a 4" lift, rs9000 shocks, drop pitman arm and dual steering stabilizers. 35" nitto tires on mickey thompson rims.
I cannot seem to get the steering to work right. What am I missing? Any help would be cool!
Pugsly
Welcome to the Z.
Have you had a professional alignment or have you aligned it to OEM specs?
Pugsly
Post a picture up of the front axle. It's easier to determine what may be wrong. You can email it to me if you can't post.
gman@savvyoffroad.com
yes to the wheel alignment. the jk will be back in my shop on monday and i will take fron axle pics. are photobucket attachments acceptable here? if so i can easily upload them.
OK, we rechecked the alignment and changed to bigger shocks and a double steering stabilizer. seems better, but still wanders. especailly when you hit bumps (bump steer?) I am wondering if more caster would help. It feels just like you are riding a bicycle with the handlebars turned around backwards.
Question, is the a long arm kit available for the front axle that has adjustable caster?
Thanks in advance! Jim
