Thread: Have a mystery
    icecastle's Avatar
    icecastle is offline Junior Member
    Feb 2011
    8
    Question Have a mystery
    I need some help.Have a 91 YJ with 2.5L fuel injected.It was running fine then I parked it in garage for 3 weeks.When I went to start it it wont fireI have checked the fuses,the timing,has good spark.I can hear the fuel pump build up and shut off after you try to srart it a few times you can smell gas at tail pipe.Need help please thanks.
    kcbugs's Avatar
    kcbugs is offline Junior Member
    Jan 2011
    6
    Re: Have a mystery
    I assume that "won't fire" means that the engine is, at least, turning. I'd start with the rotor and distributor cap. If that doesn't fix the problem, I'd then replace the ignition coil. It's clearly an ignition problem, so I'd bet that one of these items would be an easy fix.
    icecastle's Avatar
    Feb 2011
    8
    Re: Have a mystery
    It does have realy good spark.But doesnt even try to fire.Could it be something in the computer? the codes that I get are11,33,12,55does that give any more of an idea? thanks
    tp=n=yj's Avatar
    tp=n=yj is offline Member
    Jul 2009
    HANOVER,PK IL.
    37
    Re: Have a mystery
    the book shows no code 12 maybe 21 witch is oxygen sensor or circuit orcheck plug connecteror
    sweetpeet's Avatar
    sweetpeet is offline Senior Member
    Apr 2009
    marietta/statesboro, GA
    549
    Quote Originally Posted by icecastle
    You answered your own question. Code 11= ignition problem. So I think you need a new ignition coil. I know you said you get a spark but does the job go all the way through the rotation? Just a thought: your ignition coil may be good but what this code is telling you is that it could be anything between your ignition and the spark plugs. So look very carefully at each part for damage and take age into account. But I would replace the coil.
    And code 33 is ac relay just FYI.
    tow_hook's Avatar
    tow_hook is offline Senior Member
    May 2009
    western pa
    183
    Re: Have a mystery
    maybe a mouse made a new home? pop the hood, and check the wires...
    Current rides:
    57"cj3b, getting restoflyed :)
    95"yj, now on 33's
    93"xj, 37" r.i.p.
    02"wj, 33" km2's, and h.o.
    98" xj a wanta be rock krawler
    " bent, broke & twisted ( 4x4 club ) " are you?
    http://www.bbnt4x4.org/
  7. #7
    icecastle's Avatar
    Feb 2011
    8
    Re: Have a mystery
    oops the code 12 was typo code 13 instead.The spark is realy hot will jump about 3/4 "with plug out.Just wandering if getting full fuel through the inj.just checked it is 40# when cranking is this a norm when not running? thanks
  8. #8
    sweetpeet's Avatar
    Apr 2009
    549
    There is no code 40, but there is a 41 and 42. They both deal with an opened or shortened circuit either in a relay or between a fuel sending unit and a control circuit.
  9. #9
    icecastle's Avatar
    Feb 2011
    8
    Re: Have a mystery
    That isnt code 40 rather 40 LBS of pressure sorry. Thanks
  10. #10
    icecastle's Avatar
    Feb 2011
    8
    Re: Have a mystery
    Ok here is an update read something in another thread about too much fuel.thought I would try messing around that direction.I pulled out the fuel pump relay and cranked till fuel press. dropped then it started to fire.Then put relay back and it started up and ran good.Now any ideas about that? The fuel pressure now when runing is 31psi W/vacuum line hooked up and holds that when off.
  11. #11
    Bounty__Hunter's Avatar
    Nov 2002
    Southern Illinois
    13,425
    Re: Have a mystery
    The fuel pressure should be something like 31psi and 39psi, one for vacuum and the other without.
  12. #12
    sweetpeet's Avatar
    Apr 2009
    549
    Re: Have a mystery
    Quote Originally Posted by icecastle View Post
    now your having no troubles firing it up?
  13. #13
    icecastle's Avatar
    Feb 2011
    8
    Re: Have a mystery
    I have tryed it mabe a dozen times now seems ok even run it til hot then tryed still ok.
  14. #14
    tjlboise's Avatar
    tjlboise is offline Senior Member
    Jan 2011
    Boise, ID
    753
    I love it when stuff practically fixes itself. Don't know what else to say really. I guess just drive it til it breaks again. :shrug:
    Roads? Where we're going, we don't need...roads
  15. #15
    sweetpeet's Avatar
    Apr 2009
    549
    Well, I always say if it ain't broke, don't fix it. Lol
  16. #16
    icecastle's Avatar
    Feb 2011
    8
    Re: Have a mystery
    thanks guys.This is the best site for info.
  1. mystery hose. where does this go?
    By dustin g in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 12-04-2010, 04:03 PM
  2. My '93 YJ switch mystery
    By M G D in forum CJ YJ TJ and JK
    Last Post: 11-21-2010, 09:29 PM
  3. Help! 304 2100 stalling mystery.
    By Papalybbs in forum CJ YJ TJ and JK
    Last Post: 12-20-2009, 08:49 PM
  4. Marvel Mystery Oil
    By sicnik in forum General Chat
    Last Post: 11-01-2005, 08:49 AM
  5. Mystery Axle
    By SenorCole86 in forum CJ YJ TJ and JK
    Last Post: 06-15-2005, 11:01 PM
