measurements
Snitty
does anyone know off hand the measurements on a yj of the rear axle mounting surface to surface... and the spring perch center to center... i'm lazy i guess
[addsig]
1062440
Not lazy, smart. Always ask first, why re-create the wheel?
My 92-factory manual gives these measurements on the rear frame (millimeters)
Uh, sorry Snitty - I spoke too fast. I'm sitting here with the book, and it has all these measurements for the frame, so I though it'd have what you needed. But, alas, it has everything but. :-(
Need to know the distance between rear body mount holes in millimeters???
blue
[addsig]
1062561
Specs
The Dana 35c is the axle used in all YJs (Wrangler) from '87-'95 and it is the standard axle in the TJ (Wrangler), ZJ (Grand Cherokee), MJ (Comanche), and XJ (Cherokee). The Dana 44 is an optional axle on the TJ, ZJ, MJ, and XJ. Some XJs were built with the corporate Chrysler 8.25 axle as standard. The TJ and ZJ versions are coil sprung, the XJ version is leaf sprung (spring over), and the YJ and MJ versions are leaf sprung (spring under).
Model/Version Spring Pads Wheel to Wheel Years
Dana 35c/XJ NA NA '84-
Dana 35c/MJ NA NA '85-'92
Dana 35c/YJ 40" 60" '87-'95
Dana 35c/ZJ NA NA '93-
Dana 35c/TJ NA NA '97-
Hope this is of some help, I found it on off-road.com/jeep/tech/axle[addsig]
1062568
wow... thats uncommon... everything is NA except for what I am looking for... usually I need what is NA... thanks my man
[addsig]
