    mackdogman's Avatar
    mackdogman is offline Member
    Feb 2013
    32
    83 cj7, 4.2 / t15, 11" clutch or 10 1/2?
    I have a 83 CJ7 with a 4.2. The thing is when I traded for this jeep a few months ago it had a slight knock in the motor & could tell the guy had siliconed the crap out of the trans & t case mounting surface. Well long story short I built the engine and went through the trans & t case (T15 & D20). All is good to go except a new clutch. The one I took out of it was rigged some how. The flywheel & pressure plate surface was scared up on purpose. My guess is to make it grab long enough to trade. The problem I have is everywhere parts store I look they have a 10.5" disc. The one that came out of it was a 11" disc. Should I use what it calls for or is a 11" an upgrade?
    Thanks for any help.
    69jeepcj's Avatar
    69jeepcj is offline Senior Member
    Feb 2012
    Cincinnati, Ohio
    1,993
    Re: 83 cj7, 4.2 / t15, 11" clutch or 10 1/2?
    I would replace it with what came out of it. the 11" would be a bit stronger than the 10-1/2", and I would have the flywheel resurfaced. I think the 11" was used in earlier years, either one will work fine. I just looked at morris 4x4 centers webpage and it shows 11" clutch for 80-83 cj. I would recheck your stores and tell them to look again.
    PoliceMonkey161's Avatar
    PoliceMonkey161 is offline Senior Member
    Dec 2011
    Ellicott City
    589
    I like what 69jeepcj said.......... He's right, you can use either the 10.5 or the 11". I just went through a similar problem with my 86 CJ7 when a bought a 258 from a 80 CJ7 as a engine rebuild project. As long as the pressure plate bolts to the flywheel and your pilot bearing match the input shaft, the choice is yours.
    mackdogman's Avatar
    Feb 2013
    32
    Thats what I was thinking also. I work at a big truck dealership. I already turned my flywheel, when I was pulling the crank out to replace bearings I noticed someone tried to pull the old pilot bearing out but gave up half way. You win some & lose some when you trade. With all the work I have done I still don't think I have lost anything. Thanks for you guys input.
    Dec 2011
    Ellicott City
    589
    Not sure what you traded to get your CJ7? But I looked at your intro post and the tub looks in good shape (barring the paint coming off). You're off to a great start with the engine and trans. IMO..... You have a blank canvus ready for you to create a mater piece!
    mackdogman's Avatar
    Feb 2013
    32
    Thanks. The tub has a little rust like normal but will fix all that before putting the body back on. I plan on doing a spring over axle setup and take the long shackles off. I also plan on moving the shackles on the steer axle to the rear to make it more stable and less stress on the steering gear.
    I traded my 2003 Suzuki street bike for the jeep. I didn't have but 2grand in the bike. After getting pulled over at 43 years old for speeding I figured its time to start playing on 4 wheels instead of 2. I also traded my dirt bike for a 4 wheeler lol imagine that.
  7. #7
    mackdogman's Avatar
    Feb 2013
    32
    One more question on the clutch. The throw out bearing that came out of it was the kind that was round & a groove in it for the fork. I am looking at a 11" clutch but it has a bearing with clips on it. Will either work or just go back with what was in it like you guys said?
  8. #8
    69jeepcj's Avatar
    Feb 2012
    Cincinnati, Ohio
    1,993
    pretty sure either will work
  9. #9
    Dec 2011
    Ellicott City
    589
    What year is the trans from? I believe there are two different style of forks 72-75 and 76-86? You mentioned a D20 transfer case which would be from an earlier model Jeep, right? Regardless, the forks can be inter-changed if needed. I would buy my pressure plate, disk and bearings as a set.
  10. #10
    mackdogman's Avatar
    Feb 2013
    32
    Yes On the D20 but the T15 trans had the round no clip style but I also have a T14 Im going back with that had the clip style. Bot the T14 & T15 had the same style forks. Im pretty sure either will work also I just like to do it right the first time. The T15 only needs a shifter rod & shift tower. The previous owner welded on both trying to rig it to work. I have the tower fixed but I spent a couple hours with a file on the stick end were it moves the shift rails & it keeps getting 2 gears locked in at the same time. The local used jeep guy wanted $250 for a old but good tower & stick for the T15 but found a T14 with another D20 attached for $150 via CL so I went with it. The sad part is neither person know what year Jeep the trans come out of but from research I would say both were mid 70's Jeeps.
  1. 83 CJ7 Quit running on highway
    By jprtroy in forum CJ YJ TJ and JK
  2. 83 CJ7 Straight 6... Do they have a computer?
  3. 83 CJ7
    By Jeepr89 in forum General Chat
  4. 83 CJ7
    By CJKrazy in forum Items for Sale, Trade, or Give Away
  5. 10.5 OR 11 INCH CLUTCH HOW DO I KNOW???
    By jeepster in forum CJ YJ TJ and JK
Tags for this Thread
