    Barrett's Avatar
    Barrett is offline Junior Member
    Feb 2015
    Central Florida
    12
    How to trouble shoot 4WD indicator lights on instrument panel (next to speedo)
    The 4WD indicator light s are not working on my 95 YJ and I would like to learn how to troubleshoot them so I can get them working again.
    Does anyone have experience in this regard?
    Care to share?How to trouble shoot 4WD indicator lights on instrument panel (next to speedo)-dash-instruments.jpg https://postimg.cc/image/ozc8ah0vj/
    Thanks!
    Bounty__Hunter's Avatar
    Nov 2002
    Southern Illinois
    13,424
    Re: How to trouble shoot 4WD indicator lights on instrument panel (next to speedo)
    It's an electrical switch on the vacuum disconnect motor attached to the front axle. The problem is most often a vacuum leak not allowing the vacuum disconnect to function as designed.
    An easy test is to remove the 4 bolts holding the vacuum disconnect to the front axle (passenger side). With the key in the run position (engine off), move the shift fork by hand and see if the dash light activates.
    In the '95 YJ, if the dash light isn't activated, good chance the front axle is not engaged, leaving you with 2wd.
    Post up what you find.
  1. Instrument panel goes to zero
    By stearmanman in forum CJ YJ TJ and JK
    Last Post: 10-22-2016, 04:21 PM
  2. trouble shoot.
    By MB63 in forum CJ YJ TJ and JK
    Last Post: 01-10-2014, 03:58 PM
  3. indicator panel
    By south7069 in forum CJ YJ TJ and JK
    Last Post: 08-20-2012, 02:06 PM
  4. instrument panel
    By jakbob in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 12-03-2005, 04:00 AM
  5. Instrument Panel Lights
    By dingus in forum CJ YJ TJ and JK
