    hewarren's Avatar
    hewarren is offline Junior Member
    Jul 2019
    1
    06 rubicon unlimited console removal
    how to remove the auto matic shifter console? i think the shifter grommet gave away.
    TerryMason's Avatar
    TerryMason is offline Administrator
    Dec 1999
    Virginia Beach VA
    7,877
    Re: 06 rubicon unlimited console removal
    I've got an 05, so it's likely the same. The console is essentially two pieces - the front and the back.
    If memory serves, you take out the cup holder insert, and there are some phillip head screws there. Next, you pop out the flat part around the shifter, It just pulls up, then there are screws under that that you remove to get the entire front of the console up.
    Let me know if you need some photos and I'll take a few
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,665
    That is correct if you want the center storage out. From there remove the rear cup holder bottom rubber insert. You will find two bolts to remove. With the front detached it should pull out. Nor sure if you have s factory sub in there what needs to be removed.
  1. 05 rubicon unlimited
    By Robfitz in forum CJ YJ TJ and JK
    Last Post: 07-08-2014, 07:23 AM
  2. 05 Rubicon Unlimited
    By Robfitz in forum New Member Introductions
    Last Post: 07-08-2014, 12:27 AM
  3. Center console/dash removal 08 jk
    By MickDet08 in forum CJ YJ TJ and JK
    Last Post: 01-12-2009, 08:54 AM
  4. Center console removal
    By jeeprookie in forum CJ YJ TJ and JK
    Last Post: 08-13-2005, 09:04 PM
  5. cherokee console removal
    By mujaman in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 06-04-2005, 09:13 PM
