99 TJ gear questions
Terry Henline
if I upgrade the gear ratio from 3.55 to 4.10, Cant i just change the ring and pinion gears? I know I have to change out the front differential to hold the 4.10.
Thanks,
Terry
Yes but there is more to swapping the unbolting old and bolting new...
Speedo gear to keep it correct.
Thanks,
Terry
That's our plan for the incoming TJ project we will work on right after finished installing the brake kit and truck wheel and tire packages for the Silverado project. Would appreciate if you do some write up on your progress.
