Turn Signal Switch Help!!
I just installed a blinker switch in my CJ when I installed my Painless wiring harness.
Remove the steering wheel to get to the steering wheel lock-plate. Then remove the lock-plate "keeper" with a lock-ring tool, I borrowed mine from Auto-Zone. Once you get the lock plate off, its just a matter of 3 machine screws and fishing the wiring harness down the column. If you have the part and the correct tools, it should take less than an hour.
It's worth the effort.
85 CJ7
I just did it, what he said but the steering wheel and the lockplate were not co-operating. And be careful of that little horn tower, it breaks easy,cause I know.
