    sicnik's Avatar
    sicnik is offline Senior Member
    Jul 2003
    Kansas
    181
    RE: sticker
    Have you ever heard of Marvel Mystery Oil? What are the Pros / Cons?
    Should I put this in my YJ?
    Thanks for any input.
    Nick
    sicnik's Avatar
    Jul 2003
    Kansas
    181
    RE: Sunday Night Chat
    I take it from all the responses that Marvel Mystery Oil will remain a Mystery... :?
    prariepunk's Avatar
    prariepunk is offline Senior Member
    Feb 2005
    Huron, OH
    1,493
    But I don't know how to find it
    2005 TJ X
    - 4" SkyJacker Sport Lift
    - TeraFlex Super Short SYE
    - Tom Woods rear driveshaft
    - 33" General Grabber AT2 on Cragar Soft 8
    - ARB Safari Snorkel
    - Warn XD9000i
    The Proud President of the CAN'T HURT DIRT MUD SLINGERS, 'Cause you can't hurt dirt!
    Zach "prariepunk" Harpst
    fuelly
    sicnik's Avatar
    Jul 2003
    Kansas
    181
    I've found it and have a bottle at home, used some in my bike's fuel to clean the valves. Was just wondering if anyone has ever heard of it before. My experiance so far is that not many people have heard of it. Its suppose to be some good stuff.
    90Xjay's Avatar
    90Xjay is offline Senior Member
    Nov 2003
    Texas
    3,626
    What do you want it to do in your Jeep?
    Why do you think you need it? What are you trying to accomplish?
    Do you want to run it in your gas tank or oil crankcase or both?
    My thoughts....I use it in my gas tank everynow and then to keep the system clean and it also promotes keeping o-rings in good shape.
    In the crank case...in modern engines...not needed and when you add this product you are really thinning out your motor oil..I just don't see why adding a bunch of additives to your motor oil helps, when you run a 10W30 or 5W30 then add something to raise or lower the viscosity of the product, why not just run a different weight to start with...?
    sicnik's Avatar
    Jul 2003
    Kansas
    181
    I am adding it to the fuel system, maybe a little in the oil I have a slight ticking noise. I have done research on the product and know what it does or is supposed to do. I just thought it strange that most people have never heard of MMO, figured it would be an interesting topic.
  7. #7
    90Xjay's Avatar
    Nov 2003
    Texas
    3,626
    Yeah, me too. Marvel has been around for a long time and I thought all over the country. I guess it used to be real popular in the older V-8s and engines built with less tolerances to cushion valves.
    I see what your saying for a possible sticking valvle or lifter, it just might work to clean out gum or sludge. Good luck with it.
    90
