1. 2004 Overland steering
    Good morning I have a'04 Grand Cherokee Overland, had a shop rebuild my front end. They used a kit for a'04 Grand Cherokee. It now drives horrible all over the road. Are there different lengths of the parts for an Overland? I believe it has a small factory lift. Thank you. I'm in La Grange California
    Feb 2009
    Dayton Ohio Area
    6,313
    Re: 2004 Overland steering
    No. Parts are the same. But not every shop knows how to properly align a 4x4 with a lift. My guess is the toe is to great.
    Start with doing a dry steer test to be sure nothing is loose or worn.
    Engine off. Someone moves steering from lock to lock while another inspects all tie rod ends. Connections and bushings for movement.
  3. Re: 2004 Overland steering
    To check alignment all you need is a tape measure. Measure same point to same point on front of tire, then repeat on back of tire, then you will at least know if its alignment and how it needs to be adjusted if it is.
    Sent from my SM-A205U using Jeepz.com mobile app
  1. Vermont Overland Trophy
    By Josaff in forum General Chat
    Last Post: 02-18-2013, 09:29 PM
  2. 2004 Overland
    By floyd5194 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 08-02-2010, 12:31 PM
  3. Overland Navigator
    By spatialminds in forum Jeep Electronics and Audio
    Last Post: 07-29-2010, 01:48 AM
  4. 2004 Grand Cherokee Overland with Intermittent heat problem
    Last Post: 05-10-2009, 10:32 PM
  5. Wanted - Air Box Assembly for 2004 Overland
    By floyd5194 in forum Items for Sale, Trade, or Give Away
    Last Post: 05-08-2009, 01:53 PM
Tags for this Thread
