I have an 01 XJ with 162K on it, that has a few little "nuisance" problems that we've had to just "live with", for a while; but now I have it in the garage, "down for maintenance" to take care of some of them;
one of these, has been what I can only describe as a "mini death wobble" because it only does it between 50-55; we've had it since 94K and it has ALWAYS been there; but while the speed range has not increased, the intensity has; 3 sets of tires between 2 sets of wheels (the set that was there when I bought it + 2 replacement sets) tell me that it is NOT tires/wheels/balance;
I pulled the front diff today, so I could replace the front 4-link bushings; (there are 2 that go directly in the diff housing, these 2 were both very weak
on the right upper one, the bushing sleeve was loose in the diff housing, even, pushed irt out of the diff with my fingers!
I had bought some urethane bushings like eons ago, to put into this thing; finally got around to it today. I burned the old ones out with a propane "bottle torch" (why do urethane ones, NEVER come with the outer sleeves?) and bead blasted the shells to get rid of the last little bit of old bushings left over; then I tack welded the shells to the control arms, to be sure they don't move; the rt. top one I tacked to the housing, the left top one, I put a couple globs of weld (since the housing is cast iron there) on the shell to retain it; all done with an oxyacetylene setup the "old" way; got all the new bushings in, ready to put the diff back into place tomorrow;
Any opinions here on urethane bushings??? (vs replacing them with OE type rubber) I have no lift kit on this Jeep; I have 235/75-15 highway tread tires on, this thing don't see 4WD except in the winter (we live in the country) more for the wife's "piece of mind (it's her ride) I went with the urethane since the "death wobble" is basically the result of the front diff shimmying side to side within the chassis; so I figured the stiffer bushings might alleviate that. I also have a new track bar going back in as well; just because of the mileage issue. as long as the body holds up I plan on running the wheels off this Jeep; no plans to sell/trade in the forseeable future. this is my 1st time using urethane, but I've heard all the complaints from the hot rod and classic muscle car world.
