91 jeep cherokee 2wd 4.0. waterpump repair
Man thanks . my 91 is mostly stock right now but she runs good haha next gotta fix the loose steering. :(
Loosen pulley to water pump bolts , then remove belts, then pulley, loosen clamps and remove hoses, remove brackets from pump, do not remove any hoses from ac or pwr steering, remove bolts and water pump, remember where each bolt went because they may be different lengths, good Idea to clean em too. Then reverse the steps with the new pump
Hi. All !! Yes. - it. Is a. GOOD. Idea. To. Pay. Attention. To. The: Length of. Water. Pump. Bolts. And. Their. Location. Make. A Note. Of. Their. Length. And. Location. Also, GOOD. IDEA. To. Replace. The. THERMOSTAT. At. The. Same. Time ! Cost a. Few. Bucks. - But. Well. Worth. The. $$! Also, you. MIGHT. Want. To. FLUSH. Your. Cooling. System. Out. - At. The. Same. Time. Check. All. RADIATOR. Hoses. Too! Might. Need - R. And R! Good. Luck! JB
