Bond--007
HISTORY: About 2 weeks ago this issue occured and I got a CEL for the following code - Intermittent loss of either camshaft or crankshaft position sensor. I assumed it was due to the generic CKP I put in back in Aug '14. The Seller sent me a new one and I installed it last night. and took it for a test run (~7 miles). Ran great during the test run
I jumped in the jeep this morning to take it to work since it is calling for nice weather. Made it about 4 miles from the house and noticed a slight "burp" in the throttle. Within another half a mile or so, it really started to stumble and miss. Everytime it would stumble, the RPM would surge to 4000-6000 but no change in the engine sound. The stumble goes go away if the clutch is pressed in. I tried the dash cluster trick to pull a code but it only showed a 23 code
[TABLE="width: 90%"]
[TR="class: table_trans"]
[TD="class: body8_black, width: 9%, bgcolor: #e8ecb0"]23 [/TD]
[TD="class: body8_black, width: 91%, bgcolor: #f9fae4"]Intake air temperature sensor input above or below acceptable voltage[/TD]
[/TR]
[/TABLE]
I was so ticked I had to take the truck on such a nice day, I slammed the door closed and left. I have a scanner at the house to hook up tonight to pull the code that tripped the CEL. Was reaching out here to see if anyone has experienced this in the past and what I should look at
In previous searching on the web, people that had the same issue claimed they fixed it with a new distributor assembly, CKP sensor, or timing chain
1997 Wrangler SE
2.5L Engine
5 speed manual trans
[/TR]
[/TABLE]
1997 Wrangler SE
2.5L Engine
