So last week I'm down at NAPA to get a new plug socket, (the old NAPA branded one I had lost the rubber inner sleeve) they no longer had NAPA branded plug sockets but they warrantied this with one by the Carlyle line. I noticed that the rubbet inner boot opening was larger and didn't hold the plug by the ceramic sleeve but by the tip of the spark plug instead. :shades:
Tightening down the no. 6 & 8 spark plugs on my 360, you know, the two that you have to access from under the CJ's, and I heard the ceramic crunch and sure enough the ceramic was broken. I thought that I may have pulled at the odd angle one has to address those no. 6 & 8 plugs was the reason. Gingerly I tightened down the others on 2 & 4 and moving to the plugs on the left bank no. 7, (that I had a straight, clear of obstruction shot at) also crushed the ceramic on the plug. :x I'm not new to changing spark plugs on my Jeep but this is getting right infuriating, considering that my trusty old NAPA plug socket never once cracked/broke the ceramic on any plug on the various AMC, Ford and Chevy's I've used it on.
Do y'all reckon this is just a bad casting or a design flaw?
Tightening down the no. 6 & 8 spark plugs on my 360, you know, the two that you have to access from under the CJ's, and I heard the ceramic crunch and sure enough the ceramic was broken. I thought that I may have pulled at the odd angle one has to address those no. 6 & 8 plugs was the reason. Gingerly I tightened down the others on 2 & 4 and moving to the plugs on the left bank no. 7, (that I had a straight, clear of obstruction shot at) also crushed the ceramic on the plug. :x I'm not new to changing spark plugs on my Jeep but this is getting right infuriating, considering that my trusty old NAPA plug socket never once cracked/broke the ceramic on any plug on the various AMC, Ford and Chevy's I've used it on.Do y'all reckon this is just a bad casting or a design flaw?
