1. 03 G.C.Injector fuse
    4.7.H.O.I have blown 2 injector fuses on hard acceleration since replacing alternator and starter was it something I did?
    Feb 2009
    Dayton Ohio Area
    5,543
    Check the wiring for shorts.
    Check your engine mounts.
    If you quickly rev your engine from idle above 3300rpm and down to idle does the engine rock heavily? It could be pinching the wires.
    Re: 03 G.C.Injector fuse
    Thanks, i was also told to check the green,black wire running from ASD relay to ECM so I guess I have to take out the PDC out of the way along with coolant reservoir to get at it, motor mounts seem fine.
  1. 98 TJ #1 Injector Problem
    By JeepJerk in forum Jeep Electronics and Audio
    Last Post: 05-22-2017, 04:35 PM
  2. injector issues
    By boutmlyn in forum Wrangler and CJ
    Last Post: 02-19-2013, 01:50 PM
  3. Leaking injector
    By 89grey4x4cherokee4.0 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 04-30-2011, 08:34 PM
  4. Injector Help
    By captjanes in forum Wrangler and CJ
    Last Post: 02-03-2011, 05:58 PM
  5. injector upgrade?
    By ademondad666 in forum Wrangler and CJ
    Last Post: 11-02-2010, 10:54 PM
