    CamoTJ's Avatar
    CamoTJ is offline Junior Member
    Jul 2009
    Memphis, TN
    4
    Wiring path for Driving Lights--HELP!
    I am trying to wire driving lights that are mounted on the windshield frame, but I can't find a good path for the wires. I was thinking about drilling a hole in the cowl and then routing the wires into the engine compartment, but I can't find a good way to get back through the firewall near the fuse box. There are a lot of holes and grommets that I could use near the steering column and peddle box, but I prefer to keep all the wires near the fuse box (so I don't have to extend the harness for the lights). Any suggestions???
    JeepMonkey's Avatar
    JeepMonkey is offline Senior Member
    Jun 2003
    Clovis, California, United States
    953
    Re: Wiring path for Driving Lights--HELP!
    No need to drill! I did a good write up on the ones I mounted, but it's long gone. However, I have some pictures of the finished product if you want. You can flip your windshield down and snake the wires into the cowl from there. I think the only drilling I did was on the inside of the cowl into the engine compartment.
    Attached Thumbnails Attached Thumbnails Wiring path for Driving Lights--HELP!-img_0074.jpg
    Attached Files Attached Files
    '01 TJ, 4.0/5spd
    6" Rock Krawler X-Factor Long Arm, 35" BFG M/T's
    4:88's, ARB's
    BOHICA!
  1. Off-Road (Driving) Lights on XJ Roof Rack
    By dingus in forum Accessories
    Last Post: 09-28-2013, 11:47 AM
  2. brand spankin new IPF 960 driving lights
    By LGR in forum Items for Sale, Trade, or Give Away
    Last Post: 06-28-2004, 09:25 AM
  3. Factory Driving Lights
    By southtj in forum CJ YJ TJ and JK
    Last Post: 01-21-2004, 08:34 AM
  4. YJ Renegade after market driving lights
    By enduser_98 in forum CJ YJ TJ and JK
    Last Post: 01-04-2004, 12:58 PM
  5. Wiring driving lights in to reverse light in taillights
    By jprtroy in forum CJ YJ TJ and JK
Tags for this Thread
