1995 Grand Cherokee factory alarm goes off
Dagan
I have a 1995 Grand Cherokee that every time you start the jeep the factory alarm goes off and i have to reset the damn thing before it will start up.
How can I disarm it for good just disable it so this wont happen I am about nuts having to lock and unlock the door each time i go anywhere.
Sorry I will not start your jeep anymore. :)
You might want to check your battery. Have it load tested and be sure it is 12.6V engine off. Then clean all connections power and ground terminals and opposite end of those connections.
Also check the connections to the alarm system. It sounds like your system may be bleeding down when the engine is off. Then when you turn the key it powers it. Or you have a bad connection or battery and the current draw drops the alarm voltage enough to trip it.
